2009 key fob
1 reading
14K views 14 replies 8 participants last post by  GARETHED30
#1 ·
I have a 2009 st2 a message has come up the battery in the key is low how do i change it ?
#3 ·
Lee, I think there is a time limit on from when you take old one out to placing new one in, so have new batt to hand before you take old one out Sorry I cannot refer to my handbook but there is something in there)
#6 ·
Sorry to jump this thread.
Alb, I now have 2011 Mondeo Sport. Basically the Mondeo H/Book says same as the pdf you gave us.
But, the Mondeo book does not tell me how to reprogramme a remote control WITHOUT a folding key (The type I have with power start/stop button) and no ignition barrel.
IIRC the ST book has the info in I want. If it has can you do me a pdf please, thanks' Trevor B
#7 ·
Yep I need the same advice if anybody has got it please. My ST has the power start up button and no folding key. My spare key doesnt work at all and ive put a new battery in so I need to programme it to the car. if I lose my main key I'm screwed. I'm sure ford would charge me to do this and sounds like an easy task I could do in 5 mins if I had the info.
#9 ·
Thanks for the download Alb but if I am reading it right there is nothing in there that applies to my set up.
I have no ignition barrel on my car to put a key into - just like the facelift ST (praps there is nothing in the ST H/book either)
#10 ·
Ive got exactly the same issue trevor. No ignition barrell, just the push button start up. Ive had a look round google searching but struggling and it will pain me to pay ford for a job that I bet is simple. I will keep looking and let you know, and if you do the same. I came so close to accidentally dropping my keys down a drain in a car park the other week it wasnt even funny!! Gotta get my spare key working.
#13 ·
Lol, nice one Alb. Low and behold remove the plastic cover and theres a nice slot for the key. Cant believe I didnt think to look under there but thought it was a permanent fitting.
.... now for programming that fob.
#15 ·
Hi, I recently bought an ST3 with the same problem but luckily for me it was my spare key. After many hours of searching you cannot programme this fob yourself as like you say the ignition barrel does not turn. Basically you have 20 seconds to replace the battery in the key fob, if you don't then you need to take it to Ford and yes you've guessed it they want ÂŁ110 to re-programme it (rip off).
By the look at it you can re-programme it via the data port so maybe an auto electrician with the right equipment would charge less as it should only take about 10 minutes. Let me know if you have any luck
