101 - 120 of 148 Posts
Discussion Starter · #101 ·
I had another day on the puma today, did the passengers side wheel bearing and hub, track rod end, control arm and strut top and bearing. I also replaced the screen wash pump which leads onto what I posted in the general rant thread.
Automotive tire Vehicle brake Locking hubs Motor vehicle Rim
Automotive tire Motor vehicle Locking hubs Vehicle brake Rim
The control arm was in much the same condition as the drivers side, with the poly Bush torn and the rose bearing rusty.
Tire Automotive tire Road surface Asphalt Tread
Purple Violet Electric blue Circle Jewellery
Automotive tire Bumper Gas Automotive exterior Automotive wheel system
Planer Blue Gear Machine tool Wood
Blue Gas Machine Automotive tire Gear
Blue Gas Machine tool Machine Engineering
Tire Wheel Automotive tire Automotive lighting Locking hubs
Automotive tire Gas Engineering Machine Auto part
Discussion Starter · #102 · (Edited)
Continued.
Tool Machine tool Milling Engineering Gas
The strut top and bearing was a fairly easy job at least.
Automotive tire Audio equipment Electrical wiring Hood Automotive design
Household cleaning supply Purple Flooring Floor Household supply
Automotive tire Tread Gas Composite material Automotive wheel system
Building back up.
Automotive tire Motor vehicle Gas Machine Bicycle part
Motor vehicle Automotive tire Vehicle brake Locking hubs Bumper
Now for what I thought would be a 10 minute job.
Circuit component Font Electric blue Auto part Fashion accessory
I pulled the inner arch liner to find this.
Shoe Automotive tire Hood Motor vehicle Automotive lighting
All washed out.
Fender Gas Tints and shades Rim Wood
I scrubbed and wire wheeled it then rust treated it. Once that dried I started to paint it, and gave it 3 coats.
Wheel Tire Automotive lighting Automotive tire Hood
I'll wait for I to dry then give it a few coats of waxoyl.
Discussion Starter · #106 ·
I haven't done much on the millennium recently, just enjoying it.
Tire Wheel Car Sky Vehicle
I have fit some new door speakers.
It took me a few weeks of trawling through the internet looking for the correct speakers. I wanted the biggest I could fit without needing adapters or without cutting the door.
I finally settled on these. Although quite expensive for a pair of speakers.
Camera lens Camera accessory Cameras & optics Camera Material property
Thankfully they fir perfectly without any modifications, although I did make a small wiring adapter to go between the speaker terminals and the original ford plug.
Automotive lighting Automotive tire Product Motor vehicle Camera lens
Automotive tire Automotive lighting Motor vehicle Automotive design Alloy wheel
While they were expensive, I think it was worth it for how good they look and sound. The only problem now is the rears need doing as they can't keep up.
Also this arrived today, A mishimoto oil sandwich plate with 3 1/8 npt ports to plumb in the sensors. I'm going to be fitting a dual oil temperature and pressure gauge.
Automotive tire Fluid Bumper Material property Rim
I found a cheap dash surround on eBay for the center vent.
Grille Vehicle Car Automotive lighting Hood
I removed the vent and the directional fins.
Automotive design Automotive tire Automotive exterior Font Gas
Motor vehicle Hood Guitar accessory Automotive design Automotive lighting
I used a 2" hole saw to cut through the rest of the fins then used a Dremel and grinding bit to tidy up.
Shoe Helmet Luggage and bags Sleeve Grey
I used an old Revotec gauge to mock up and test fit.
Watch Motor vehicle Analog watch Automotive lighting Clock
Discussion Starter · #107 ·
Car Steering part Speedometer Light Motor vehicle
I'm intending to use a spa design dual oil temperature and pressure gauge. I'd thought about removing both vents and making a plate to cover the hole and fitting 2 individual gauges bit I think the single gauge set in the vent will look neater and still leaves the other vent still functional.
Discussion Starter · #110 ·
I finally got around to fitting the gauge this afternoon. Thankfully it was relatively easy and no cutting or messing with the bulkhead was needed.
Speedometer Automotive lighting Car Hood Motor vehicle
Wired up to a switched 12v feed.
Vehicle Car Speedometer Motor vehicle Automotive lighting
Sandwich plate and sensors fitted.
Tire Wheel Hood Automotive tire Automotive lighting
Automotive tire Automotive lighting Motor vehicle Hood Automotive fuel system
All wiring connected.
Speedometer Odometer Vehicle Car Gauge
And after a short run.
Car Speedometer Odometer White Vehicle
All I need to do now is set the hi and low alarms and change the oil pressure from psi to bar.
Discussion Starter · #111 ·
I had a play with the settings for the gauge today, these are all accessed via a single button I have fit in the blank button on the dash.
Psi changed to bar.
Speedometer Car Vehicle Odometer Steering part
Oil pressure warning set to 0.9 bar, this causes the screen to change from green to red and the led at the top flash red.
Car Speedometer Motor vehicle Gauge Vehicle
Discussion Starter · #112 ·
OK, so this thread needs updating. Unfortunately a lot of the pictures are on the phone I replaced last month.
For now this is what I've done this evening in preparation for fitting this.
Automotive exhaust Metal Auto part Nickel Titanium
Wheel Tire Car Land vehicle Automotive parking light
So first this is to remove the driveshaft, this needed to come out anyway as the seal was leaking.
Tool Font Electric blue Asphalt Nickel
Automotive tire Motor vehicle Automotive wheel system Auto part Wheel
Motor vehicle Automotive tire Automotive fuel system Auto part Gas
Once the shaft is off its fairly easy to get the manifold out.
Bicycle part Auto part Bicycle fork Metal Automotive exhaust
While it served its purpose, it was an awful system with a horrible tinny raspy sound. This wasn't helped by the poor fit that allowed the system to rest on the heat shields and constantly rattle. Hopefully I'll get the new system on tomorrow.
Discussion Starter · #114 ·
And finished.
Automotive tire Motor vehicle Automotive fuel system Rim Automotive exterior
Tire Wheel Vehicle Vehicle registration plate Car
The only problem I have is the o2 sensor extension harness I made is too short as the the sportex manifold had the take off further up the pipework. Also it only measured the exhaust from 2 cylinders, which wasn't ideal. The racing puma system has it set at the end of the pipework.
Tire Wheel Hood Automotive tire Tread
Asphalt Road surface Wire Event Concrete
Grass Wind instrument Brass instrument Musical instrument Groundcover
Automotive parking light Car Automotive tail & brake light Tire Window
Discussion Starter · #117 ·
Some more fun with the puma, the gearbox torque link Is a bit on the sloppy side. There only seems to be 2 options to firm things up, poly bushes to replace the originals at £40 and a full link by vibratechnics for around £150. So thought I'd try the poly bushes first.
Road surface Font Circle Asphalt Plastic
Gas Automotive tire Engineering Bumper Metalworking hand tool
Another win for the China press.
Automotive tire Bumper Motor vehicle Gas Automotive exterior
Automotive tire Blue Wood Gas Automotive wheel system
Bare link all cleaned up.
Household hardware Gas Auto part Nickel Wood
Getting the small bush and collar in was an absolute pain in the ****. It's a 2 piece bush and when pressing the collar through it would force the second half out no matter how much I tried. After several emails to flo flex and them asking to measure everything, it turns out they'd sent me the collar for the 35mm bushes and not the 33mm bushes for the puma link. Anyway, I got there in the end.
Hand tool Wood Audio equipment Tool Gadget
Musical instrument Wind instrument Bicycle part Brass instrument Metal
I fitted it this evening, as to be expected there are some more vibrations transferred into the car but nothing too bad and only seems to be between 1500 and 2000 rpm. With a bit of luck it will bed in and calm down.
I also treated it to some engine bay bling.
Font Symbol Emblem Logo Fashion accessory
Motor vehicle Hood Light Automotive tire Automotive lighting
Discussion Starter · #118 ·
Another little job on this wet miserable Saturday.
The center console badge is well past it's best, the black paint has chipped off and looks a mess. Unfortunately the badge is no longer available, thankfully I managed to find a new old stock vct badge. These wete only fitted to the first 1500 1.7 pumas between 1997 and 1998.
Road surface Automotive tire Asphalt Tire Grey
Synthetic rubber Automotive tire Carbon Tints and shades Rim
Automotive tire Synthetic rubber Grey Rim Automotive design
Automotive tire Automotive lighting Grey Asphalt Carbon
When I owned my mk5 fiesta ZS, I opted to try the poly bushed torque mount, but for me the extra vibrations were too much, so I switched to a vibrantecniqs mount, I think I picked it up second hand, but good condition for around £60, there was a little extra vibration on idle but other than that, it was a really good product.
Discussion Starter · #120 ·
I think that's the route I'll be going, but it will have to wait as I'm having the inlet manifold blast cleaned and ported for the bigger throttle body next.
