QUOTE(fishface31a @ 31 Dec 2009, 03:38 PM)
<{POST_SNAPBACK}>
I think youll find the standard diff only drives one wheel at a time but doesnt change to the wheel with grip like the ATB does! On the standard diff the driven wheel just spins! On mine its made a hell of a difference in grip away from the line specially if you floor it in 2nd gear! It used to just light up 1 wheel but now it just digs in and goes! The only downside i have found so far is that when it does let go it understeers like a ****** and heads for the outside of the corner double quick!
I've not driven a car with a LSD yet, but when i was doing my 1/4s there was a car that had a LSD and he has a good history at launching the car and he was not getting away from the line as good as nearly every one else. It could have just been a bad day for him/his car but this is the only direct comparison i have to call up on between LSD and non-LSD. Would love to have a go with a LSD through the bends and see for my self what all the fuss is about. Hopefully catch up with you soon and you can try to convince me to add a LSD to my shopping list
QUOTE(Vtec Abuser @ 31 Dec 2009, 04:03 PM)
<{POST_SNAPBACK}>I'm with ARW on this one.. A LSD is not going to shave over 6/10th's of a second off your time mate, unless your 60ft times (not 0-60mph) are around 3+ secs? But even then that would be down to the driver more than anything..
Your 60ft time will be on your ticket mate and should be around 2.3 secs at a guess. 13.6 is a cracking time, so i'd be chuffed if I were you. What power are you running, about 300bhp? To run 12's in a ST, you are going to be needing 350bhp+ and some sticky tyres IMO
Oh and nice one on taking the RS too...
Not shore about needing over 350bhp (even if that is possible in a
), i was spinning the wheels in 3rd if i was not careful.
I'm with you on the sticky tyres, they will get you the grip and the vital 10th's to drop the time to very low 13's but i could see it taking out a few drive shafts
btw - think me saying wheel spin/slip is not the best description, when i got it wrong and added a bit too much throttle the car more bounced then doing a burn out screeching wheel (if that makes sense).
