Tuning Developments Solid Intercooler Boost Hard Pipe Kit for the popular MK3 Ford Focus ST 250 Models with 2.0 Ecoboost Engine
Item: Solid Hard Intercooler Boost Pipe Kit for Ford Focus ST250 2.0 Ecoboost
One of many parts available from Tuning Developments for your MK3 Ford Focus ST 250! Manufactured here in house in the UK, The Tuning Developments hard pipe kit for the Focus ST 2.0 Ecoboost ST250 is an absolute must for high power cars..It eliminates all the restrictions created by the standard boost pipe tract whilst offering added strength and reliability to higher boost applications.
Made from full Stainless Steel for maximum strength and performance with all Bends CNC Mandrel bent to ensure the maximum airflow, while allowing for a 100% bolt on fitment to the 2.0 Ecoboost engines.
We supply the full kit, replacing the restrictive steel 50mm link pipe from the turbo to intercooler with a full length hard pipe with 63mm (2.5inch) bore.
The intercooler to throttle body pipe is also replaced with a free flowing pipe - eliminating the restriction step down of the oem set up.
Included:
Mandrel Bent Stainless Steel True 2.5inch "Hot Side" Boost Pipe
Mandrel Bent Stainless Steel True 2.5inch "Cold Side" Boost Pipe
5x 4ply Silicone Hose Couplers
10x Stainless Steel Tbolt Clamps
Solid Hard boost pipes come finished as pictured in Brushed finish, other finishes available at extra cost, please contact us
Our standard kit will fit with the Standard intercooler and our Wagner Tuning Intercooler Cores.
Our kit may also fit with other aftermarket coolers if the intercooler outlets are in the standard position.
Fitment:
MK3 Ford Focus ST 250 2.0 Ecoboost Hatchback 2012-on Solid Hard Intercooler Pipe Kit
Ford 2.0 Ecoboost Solid Hard Intercooler Pipe Kit
£269.99 inc VAT
